Tv Antennas and Reception
Yes the antenna will work just fine. It is the same kind of antenna as the HD7015. DO NOT use a preamp. I suggest a CM3414 distribution amplifier in the house. The television transmissions are Very Strong at your location , mount the antenna about 4 feet above the peak of the roof. Be sure and ground the coax lead in using a coax grounding block , this will direct the Very Strong Tv signals that are received by the coax shield to ground reducing interference.
