Do Not use any type or kind of amplified indoor or amplified outdoor antenna. The Tv transmissions are Very Strong at your receive location. And reflected Tv transmissions off mountains and buildings (multipath/ghosts) are very strong. An amplifier Will Over Load and be the cause of bad reception. And the Strong multipah will overload the tuner and be the cause of bad reception. I recommend a Winegard HD7210P , multipath reduction antenna. And because the Tv transmissions are Very Strong , I recommend a Model number 1296F variable attenuator to 'Dial Down' the signal strength. Aim the antenna at about 125 true - 108 degree magnetic compass.
