Thread: Uhf/vhf??
Old 15-Jul-2011, 9:32 PM   #12
Originally Posted by John Candle View Post
The NY stations will not be received the transmissions are to weak too many mountains hills and trees. A common 2 way splitter will work for 2 Tv's. For more then 2 Tv's I recommend a Channel Master CM3414 four way distribution amplifier. Any outputs of the distribution amplifier that are not connected , put a 75 ohm terminator on the output.
Agreed, NY is an extreme DX hobby project.
My personal preference would be to hold off adding an amplifier until it's proven necessary. For example, if after inserting a passive 4-way split everything works fine you're done. But if some signals are unreliable, a CM3410 could be inserted ahead of the split.
