Old 13-Jul-2011, 3:47 PM   #8
how far should these two wires remain from each other as they travel to ground?
It doesn't matter. You can run them under the same staples if you want to.
There is a copper wire that runs from the house directly into the ground.
This is the perfect location. Use a split nut (like the phone installer used) for each new ground wire to be attached to the main ground wire (probably a #4 or #6 copper) unless you can find a split nut that is manufacturer-rated for multiple wires. Simple split nuts should be available in the electrical section of any home center. Here's an example from Home Depot's site:
