Old 13-Jul-2011, 2:11 PM   #7
dprljackson
OK - so if I use two grounds for the mast and the coax and keep them separated, how far should these two wires remain from each other as they travel to ground? The mast and the coax entry point into the house are pretty close to each other (a few feet) and so these two ground wires will take very similar paths to ground.
Second question - exactly where do I connect these two ground wires? I found what looks like a ground wire where the electrical enters the house. There is a copper wire that runs from the house directly into the ground. The telephone line ground is connected to this wire via a grounding block. Can I connect my two ground wires to this grounding block or should I connect them to a different grounding block connected to this wire or something else all together?
I appreciate the assistance.
dprljackson is offline   Reply With Quote
