KTLA the CW is transmitting on Real Channel 31 UHF. The signal will be very weak at -5.1 NM(dB) try adj. the aim of the antenna for best reception of KTLA. Can also go into tvfool and raise the antenna height and see if that will move the KTLA NM (dB) number into the positive numbers. I have an other question , is K39GY Real channel 2 being received , the programing is America One.
