Old 11-Jul-2011, 2:30 AM   #6
weebl
Originally Posted by John Candle View Post
The slacker has been covered and evaluated many times. I do not recommend it and never will. Next subject , because , metal siding , metal roofs , bricks , stucko Wire , concrete and solar panels can reduce and block tv transmissions , does the house have any of these??
The house does not have a metal roof, or solar panels. It does however have concrete block/stucco construction. The antenna would be mounted above this block/stucco since the roof is a hip style so there would be none of these at the antennas mounted height in the attic.
I did have a Antennas Direct V21 in the attic that did fairly well, but due to the long rear elements my choice of mounting it was limited. Realizing that these are needed for Low Band VHF I returned it and I am looking at a High VHF/UHF style.
weebl is offline   Reply With Quote
