Old 11-Jul-2011, 12:40 AM   #3
If you are already getting good results with the CS-2 in the attic, you will probably be able to successfully add a high-VHF antenna such as the Antennacraft Y5713. Use a UVSJ to combine the signals from the two antennas into the existing coax. Keep the two antennas seperated from each other and other metal objects, by at least 4'... more is better if it's possible.
