Old 10-Jul-2011, 8:28 PM   #5
Wally9mm
Thanks for the replies.
To clarify, other than one splitter going to DVD recorder and TV3, I used individual separate cables going to each TV. I can get a WNJB signal out of the splitter at DVD/TV3 and TV4, but it drops out at times.
Although RG-6 is superior to RG-59, WNJB comes in pretty solid all the time for TV1 using RG-59. I am assuming that this is because of the low cable run of 75 feet.
I wanted to try using an amplifier to get a signal to TV2. RS has two; a 2 piece In-line TV Antenna Signal Amplifier and a Bi-directional Cable TV Amplifier.
“A UHF/VHF antenna needs to be aimed in the direction of 270 true - 281 degree magnetic compass.”
BTW according to the radar map WNJB is 257 true and 270 magnetic”.
Wally9mm is offline   Reply With Quote
