JC is on track with his questions / test suggestions. It sounds like antennas may be interconnected in ways that allow for undesirable interactions... It will be helpful to know each antennas individual performance.
WNJB, real channel 8 is adjacent to WABC, real channel 7 which is about 1000 times (30 dB) more powerful at your location. Adjacent channel interference from just 10° off the same azimuth is going to be very challenging to overcome with such a power differential.
WLIW should be 'do-able'... with a moderate gain UHF aimed at it (95° mag.).
If the amps are returnable, go ahead try them... I expect they will make matters worse though, due to noise and inter-modulation distortion produced inside the amplifier circuitry. Your TVFR does not indicate a need for an amplifier... It indicates against one due to the multitude of powerful signals which certainly includes many FM stations.
