If you try the DB-2 outdoors, you may be quite happy. The real VHF stations in the 'green' section of your report should easily be received by the DB 2, if it's given the chance.
I agree with JC that to receive the weak signal from WPXC-ION (down low in the 'red'), you'll need a large antenna as he suggests. Those weak signals would require mounting outside in the clear. The right high-input preamp would provide for distribution to multiple sets. (The wrong choice of preamp would cause more harm than good.)
Antennas designed to receive VHF are lager than UHF designs of equal gain and directivity. The frequency determines element dimensions. Lower frequencies dictate use of longer elements.
