Old 9-Jul-2011, 9:50 PM   #1
Wally9mm
Reception for NYC OTA Area -WNJB/WLIW
I am located in Queens County NY, one of the five boroughs of NYC and have no problems getting the major local signals.
I am specifically trying to lock in/improve a WNJB signal, whose transmitter I think is located in New Brunswick NJ and WLIW transmitter located in Plainview LI. Currently, the reception is either non-existent or spotty at best.
According to the TVSAR, I aimed my antenna(s) to WNJB’s transmitter (39.6 miles) at magnetic bearing 270 using a calibrated digital compass. Although WLIW (16.8 miles) is approximately 180 degrees out of phase at 95 degrees magnetic and only 16.8 miles from my location, I was unable to pick up any WLIW signal.
However, I have had limited success in getting a WNJB signal for all the HDTVs in my home. I am looking at using Radioshack Bi-directional Cable TV Amplifier (15-2505/15-2506) or RS In-line TV Antenna Signal Amplifier (1500369) for TV (No. 2).
Reception for WNJB: No reception at TV (No 2).
Very limited reception at TV (No. 3 and TV No. 4)
Very good reception at TV (No. 1)
Rooftop Reception Equipment:
Antennacraft HD850: Connected to TV (No. 3) and HDD/DVD Recorder using signal splitter. Approximate RG-59 cable length from antenna 125 feet. Separately connected to TV (No. 1) using 75 feet RG-59.
RadioShack® U-75R UHF Antenna: connected directly to HD850 lead-in terminals.
Radioshack VU 90: Connected to TV (No. 4) using 65 feet RG-6 and to TV (No. 2) 200 feet RG-59. Each connected at antenna lead-in terminals using separate cable.
http://www.tvfool.com/?option=com_wr...03d9c78d1fd99f
Wally9mm is offline   Reply With Quote
