Old 9-Jul-2011, 7:55 PM   #12
mario5678
Originally Posted by John Candle View Post
If you will like to receive and watch Tv channels starting at the top of the digital stations and channels list and on down to , WPXJ-LP ION Tv real channel 41 and on down to W45BZ real channel 45 Ocean Style Tv/Caribbean Tv. Then I recommend a Winegard HD7698P mounted above the roof so the antenna has a good shot at the Tv transmitters in the direction of , 347 true - 353 degree magnetic compass. This Tv antenna will supply signal to one or two Tv's. Here are places to buy Tv antennas and etc. , http://www.solidsignal.com / http://www.starkelectronic.com , http://www.amazon.com , http://www.3starinc.com
The current hoa will not allow that and only suprisingly allows cable dishes or cable itself. I am not concerned with every channel that far out but just receiving the green channels would be a great addition. Looking at the information provided
Channel: 7 (7.1)
Network: PBS
Maximum ERP: 18.000 kW
Coordinates: 30.281074 -81.569813
Channel: 32 (30.1)
Network: Fox
Maximum ERP: 1000.000 kW
Why I get 7.1 at a lower power than fox is puzzling. As I am no expert I can only assume like you previously noted that it can be due to reflections. Wondering if the signal functions like a sine wave and at that different signal length it causes issues.. just what ifs in my head..
best bet for me is something up in the attic as the attic is high enough I can stand up in there.. however is it typical to lose 1-3db off of the antenna rating? Regular wood framed home with a shingle roof
mario5678 is offline   Reply With Quote
