Tv Antennas and Reception
. Metal , concrete and thick bricks reduce and block Tv transmissions. Is the building wrapped with any type or kind of metal such as but not limited to metal siding or stucko with stucko Wire?? Is the building concrete or brick?? Does the building have a metal roof?? Does the building have concrete tile roof?? Is there metal backed insulation in the walls or attic?? Are there solar panels on the roof?? Is the Tv location in a basement?? The television transmissions are VERY STRONG at your location. So something is happening that only one Tv channel is being received. Does the indoor antenna have a amplifier?? If so , the amplifier is being overloaded. I will recommend a different antenna.
