Thanks John.
A couple quick questions (out of ignorance most likely).
- Will the Canadian analog channels be going digital from Analog this August during the transition?
- Would it be possible to put an attic/roof mount for the Canadian channels and run a joiner (or something) to combine the two feeds onto one coax?
I got some more information from her with regards to her plans, which forms part of the reason I'm asking the questions above. She is wanting to turn the house into a Bed and Breakfast in the next little while, and would prefer to present a 'seamless' TV experience and not have guests needing to turn a switch for watching TV. She also has concerns in having an indoor antenna/switch at each TV in the guest rooms.
If it's not possible she may just have to adapt what you recommended as best as can be done. Regardless, thanks a lot for all your assistance.
