The DB2 is designed to receive UHF frequencies... That does not mean it will reject all VHF signals though.
Have you experimented with placing the antenna outside to avoid the reflections and attenuation caused by the construction materials and appliances in the home? An antenna's performance can be dramatically affected by nearby metal objects. The effects can include changes in the directional characteristics as well as reduction of gain at some or all frequencies.
