Old 8-Jul-2011, 6:58 AM   #41
After re-reading this thread from the top, I'm leaning heavily in favor of a new antenna. The Winegard HD7694P or it's larger variants come to mind. Not because you need the gain but as ADTech says,
While the towers are in the same relative location, the signal doesn't always behave the way we want it to. You are likely experiencing what I call "frequency-specific multi-path". That usually means that you are getting an errant reflection off something on or near your line of sight that is interfering with the "primary" signal in a destructive nature.
The solution is to either try a more directional antenna (hoping to reject the reflection) or to move the antenna to a different location (up, down, left right) and try again, hoping that the new location is not bedeviled by the original reflection or a new one.
I'd like to see you get more than ten years of service from an antenna but clearly the coax in the weather needed to be replaced and the existing antenna has some damage.
I know this is redundant, but... Don't use any sort of amplifier.
