Old 8-Jul-2011, 2:36 AM   #47
John Candle
Tv Antennas and Reception
Yes you can use the HDP269 preamp with the 91XG antenna. The 91 XG will give about 5 NM dB more gain on UHF then the Philips antennas UHF section. And if thats not enough of a increase in reception then you can use the Kitztec. The Kitztech is a ultra low noise amp at .4 dB noise added to the UHF signal , The HDP269 adds 3.5 dB noise to the signal. So with the Kitztech the signal is 3 dB cleaner. And thats important with very low UHF signals at your location. I have a question , how far down the list is reliable reception both day and night being received now?? Is the WTVP-DT 46 PBS signal reliable day and night??
