Old 6-Jul-2011, 8:11 AM   #4
navagator
What are or will you be using to display the video on? The price of 1080i TVs (which include the tuner) will likely be competitive with an external HD tuner. Especially if you get to view 1080i going forward.
I'm assuming you may have a TV with SD (480i) capability. If so many HD tuners will not be able to connect and those that can, will not display more than SD video due to the limitations of the TV set.
I have a Toshiba 50HDX82 RPTV, HD ready set. It has component as well as DVI connections.
I currently have my SD/HD FTA satellite receiver hooked up through the components, it provides HD and SD video both through the component hookup. That's basically what I want in a OTA HD box as well as a strong tuner for long distance reception.
navagator is offline   Reply With Quote
