well I bought the bmu33 and the cm4221 and a 5-1000mhz signal combiner...
1 x AntennaCraft HBU33 High Band VHF UHF Fringe HD Antenna Digital Ready Outdoor 33 Element Off-Air Local HD High Definition Digital Signal Television Aerial, RED ZONE, Part # HBU-33 | With 50' FT Coax Cable (ANTU33) = $38.80
1 x Channel Master 4221-HD UHF 4 Bay HD TV Terrestrial Antenna ULTRAtenna Digital Bowtie DB4 HDTV CM-4221-HD Four Bay Outdoor Roof Top Off-Air Local Signal Digital Aerial, LIGHT GREEN ZONE, Part # CM4221-HD | With 50' FT Coax Cable (AN4221) = $29.95
1 x Pro Brand P-1000 2AP GX PBI 2 Way Splitter 5 - 1000 MHz All Port DC Passing P1000 Video Coax Cable High Performance Signal Combiner, Commercial Grade, Part # P1000-2AP-GX (SPL2PC) = $0.89
Hope I got it right, they didnt come with mounts, hope I can get them at a hardware store or something. It comes with 50 coax for each, so can i just run the separate strands into the basement and combine them there, then feed them to the distribution amplifier? I didnt buy any pre amps. should I have? Maybe I wont need them?
Can I mount the 4221 at the very top of the mast, and the hbu33 at the bottom of the mast? If I cant get to the top of the mast, can I mount the hbu33 a the bottom of the mast and side mount the 4221 on the tower below it. What should I use for seperation distance?
Thanks Again.
