FM Reception
Having the FM antenna on a separate coax means that there will be no antenna cross talk between the Tv antenna and the Fm antenna. There will be no cross talk because the two antennas will not be connected together. The Tv antenna is the Tv antenna and the Fm antenna is the Fm antenna. The Fm coax is the Fm coax and Tv coax is the Tv coax. One is one and the other is the other.
