Tigerbangs. Another question. I'd rather not purchase two antennas if at all possible. Currently I own a CM HD 4221 and the older 4228. Since I will be using the XG 91 for KMIZ TV and not for the other UHF stations, do you think I can use the 4221 to pick up the stations in yellow from KC? I'd rather not mount the 4228 right now because I am in a high wind area and the added weight of the antenna will make it susceptible to falling over during a strong storm with a roof top mount. I'd be more inclined to mount it on a tower but at this time that will not be possible.
If the 4221 is not adequate for the KC channels then I will have to spend the extra bux for a 8800.
