I was just going to ask that same question.
On FM, the C5 should exhibit an omni-like horizontal pattern with a net gain of around -10 to -15 dbi. Still, the power differential from Sutro's FM stations is still going to be somewhere around 20 dB greater than KNTV's signal if the TVFool simulation's math is even close and depending on the actual signal power delivered at your angle of depression from the towers of interest.
