STOP!
John, why are suggesting a lower gain VHF solution? While WHBF and WREX do have positive NMs, they are also 2-edge paths, so the variability will be greater. Mark, I humbly suggest that all you need to add antenna-wise is the xg-91. Use your existing antenna for VHF reception - you can't do any better unless what you have is damaged. Hook everything up as John suggests, but do not swap out your existing antenna for the CS600.
