Old 5-Jul-2011, 1:57 PM   #13
Dave Loudin
Originally Posted by Country Boy View Post
Yes John That is where I have the HDTV hooked up at if I am not mistaking. Which I very will could be. An if I am right where would you hook the TV up at? You see what they are telling me that I would have to have 2 hook ups, one for the FM radio an one for the TV. It's been 4 years since I hooked up everything and I could be mistaking.
Look at the back where the coax is hooked up - it is clearly labelled "FM". Your receiver is NOT the tuner for HDTV - you either tune with the TV or with a set-top box. Two scenarios are possible: 1) there is a splitter in the line from the antenna, with one output feeding whatever TV tuner you have and the other output feeding the receiver, or 2) whatever tuner you have has an ANT IN and and ANT OUT, with a coax from the ANT OUT feeding your receiver.
What we are saying is: do not try to combine your new FM antenna with the TV antenna's feed. Run a coax directly from the new antenna to your receiver.
