Old 5-Jul-2011, 1:15 AM   #2
I suggest receiving the Digital stations to the south east with a Winegard HD 7698P UHF / VHF high band antenna. You can put the antenna in the attic if the building is not wrapped with any type or kind of metal. Metal and concrete reduce or block reception. KUNW 2 is also being transmitted on KUNW 30 so there is no need for the HD8200U antenna. Attic installations can give a 50 percent reduction or more in signal strength. Try the HD7698P antenna in the attic , if the weaker stations such as KFFX-DT 11 are not received and you will like to receive them , you can move the antenna outside. You can Google the stations call signs that have no network listing and find out what the networks are. Read and understand about , REAL Digital Broadcast Tv Channels , Virtual Digital Broadcast Tv Channels , Analog Broadcast Tv Channels , http://forum.tvfool.com/showthread.php?t=695
