Will they both do the same job as will?
Or will one do a better job? Although the MD-10 has 4 more db gain?
There is not a dealer area where I live that handles the MD-10. So you use what your dealer can get right.
I have question: I read some where they said do not use the same lead cable from your HDTV antenna for your FM antenna why? Where would you hook up another lead cable on the back of my YAMAHA Natural Sound AV Receiver RX-V861? What they are saying you have to hook both HDTV and the FM antennas cable to 2 different hook up on the receiver right?
What would be the reasoning behind this? Would you have a filter to filter out any interference since the HDTV antenna has a FM antenna built into it? I would like to do it the right way.
