Tv Antennas and Reception
Also you can try this omnidirectional antenna Winegard MS2002 , if you can mount a antenna outside. Please understand that omnidirectional directional antennas are not truly omnidirectional. The antenna will likley need to be turned to find a sweet spot for best reception of the stations to be received. Also understand that reflected signals from tall buildings can disrupt reception if the buildings are close by. The MS2002 can provide excellent reception of widely spaced Tv stations if there is not to much interference.
