Old 3-Jul-2011, 8:57 PM   #1
True Colors
Over the air TV reception...... is it better to use two antennas instead of just one?
I have an antenna mounted inside my attic...... (FYI, it is not possible for me to put the antenna on top of my roof). Also, I do have a pre-amp hooked up.
When I point my antenna south i get good reception on a few channels but not as good with some others.
When I turn the antenna a slightly different direction I lose some reception with some channels but I gain with others.
So my question....... could I put two antennas up there pointed in different directions and merge the signals together into one feed using a coax joiner? Would that help?
Thanks,
TC
True Colors is offline   Reply With Quote
