Thread: Signal Problems
Old 30-Jun-2011, 10:09 PM   #1
turp7622
Unhappy Signal Problems
I live in Houston, TX 32 miles straight north of the Antenna Farm. Nearly every channel in Houston comes from 7 antennas in the Farm.
My Issue is that channel 2.1 (real channel is 35) will have signal strength go from 78% to 40% the to 0 and back to 78% randomly. the SNR shows about 30db then drops to 22db then 0 and back to 30db. this is the only channel that does this.
Here is my Signal Report: http://www.tvfool.com/?option=com_wr...03d94e686de3fc
From looking at the information on the Antenna Farm channel 39.1 (real channel is 38) broadcasts from the same antenna. this channel is 85% constant with no drops.
I get all other channels with no problems or drops. only the one channel.
From reading about the signal drop and bounce back, I would gather it is a multipath issue. but I would also assume that all the other channels would have same issue as all the antennas are within a square mile of each other 177 deg and 32 miles south of me. At least the channel broadcasting from the same antenna.
Antenna is HBU33 in attic.
I have moved antenna couple feet to the right and left and forward and backward but have same issue.
Anyone have any ideas on how to troubleshoot this?
turp7622 is offline   Reply With Quote
