Old 30-Jun-2011, 9:39 PM   #3
Dave Loudin
Esteban, getting an antenna with a reflector will not help with getting signals in the directions he is interested in, but your input is always welcome.
TGibson1, getting the two stations at 11 degrees with the same antenna aimed for 285 degrees will be virtually impossible without rotating it. With the RCA, you should be able to get the strong station (WAWD) off the back side, and WPAN may be strong enough to come in from the side. I think you may have the best choice for a single, fixed antenna already.
Two questions: 1) is the RCA up at 25 feet now?
2) Do you see the FOX affiliate, WALA? It is the only VHF station you have to worry about.
You DO NOT need an HD Stacker.
