Old 29-Jun-2011, 5:55 AM   #16
cableisevil
great info! i will grab the barrel and smaller slitter for sure. The eave mount you suggested looks good but wont work on my house because my eave doesnt come to a peak in the middle, it's straight across on that side of the house. I would in fact like to get as many channels as possible and from both metro areas north and south if possible. If I can't get antenna pointed to 200 mag as you suggested what would be the next best direction to get the most channels possible? Would it be better to mount the antenna in the attic and point toward 200 degrees or on the north eave outside pointing in some other direction? Is the RCA antenna I found any good? Would you recommend something different but similar?
cableisevil is offline   Reply With Quote
