Old 29-Jun-2011, 2:29 AM   #14
The coax used by the cable company and satellite TV providers will work well for OTA signals. As you have described... simply be sure the cables are disconnected from the cable company feed.
An outdoor mounted ANT-751 should provide enough signal for 2 to 4 sets. In the attic or elsewhere in the building may work also... depending on the materials used in construction.
