Old 29-Jun-2011, 1:43 AM   #12
cableisevil
that what i was going to ask in my reply that has yet to be approved by the moderator. I'm looking at mounting outside now because I found this smaller antenna the RCA ANT 751 on amazon dot com. I cannot mount on the west side because that is the front but I can mount it on the north side and feed the coax through the same soffit vent that the comcast line comes into. I will then disconnect the coax lines that I want to use off of the main comcast line and connect them to my antenna main line while keeping my internet router on the comcast line. Will any normal splitter work for this. I found the comcast on that im going to detach from and its one input and four output. I'd like to take 2 or three lines off that splitter and put them on a splitter from the antenna mainline. This would give me two or three TV's getting the antenna signal. What else should I know? You have been great!
cableisevil is offline   Reply With Quote
