Old 28-Jun-2011, 9:02 PM   #11
You can try the Winegard HD7000R in the attic. Aim the antenna at about 200 degree magnetic compass. The Winegard HD7000R antenna must not be connected to a active cable Tv line. If the Cable Tv line is active with any type or kind of cable delivered service do not connect the antenna to it. You can disconnect the cable lines that are not being used to deliver cable service and use them for the antenna connection to the Tv's.
