Old 28-Jun-2011, 1:19 AM   #2
cableisevil
also an even better solution would be just an antenna that I could buy for each TV (2 or 3) and just set it beside the TV it's being used for. Basically new age rabbit ears. That would save me the hassle of getting into the attic and doing all the 150 degree heat acrobatics. I actually bought an antenna from Kmart during the NBA finals that said it would do this. Sitting next to the TV it does nothing if I set it on the window sill it gets one channel. I had to run it out the window and set it in the gutter the night of the games to get that channel. I figured it was just never gonna work without going attic or roof mount. Seeing that I'm right between two metropolitan areas is there an antenna that would just sit next to the TV and work or are these basically just gimmicks?
cableisevil is offline   Reply With Quote
