Old 27-Jun-2011, 3:34 PM   #5
JEM
Let me clarify, one RG6 runs from the Eagle aspen control box located under our TV inside the house to the dual grounding block by the antenna then just to the rotator. The other RG6 runs from the antenna to the dual grounding block, then into the house input into a 12db Channel Vision distrubution amp inside a structured media cabinet then out ending at the Samsung SR-T451 HD tuner. I tried it with and without the 12db amp and with and without the amp built into the Eagle Aspen Rotator. I lost channels with the Eagle Aspen, and without using the Channel Vision Amp. So I am using the Channel Vision 12db amp. I lost the channels with this setup, nothing else has changed. It seems like I am loosing signal from line loss due to the long run to the antenna from the house, but also I think the antenna itself might be limited in its ability to pull in the Springfield channels and the New Haven Channels. I presently get Digital Channels 3,18,20,24,30,61, that is it. I used to get channel 57,22,40 & 10 in addition to the afore mentioned. I do not presently get 57,22,40&10. I hope this helps. Thanks.
JEM is offline   Reply With Quote
