Tv Antennas and Reception
Well Ok then install a Winegard HD7694P antenna with a Winegard HDP269 preamp in the attic. Get the antenna up as high as possible in the attic and aim the antenna at about 151 degree magnetic compass. Adj. for best reception of the weakest channel KTUL real channel 10 , virtual channel 8.1 ABC. Attach a pipe to hang down from attic roof rafter and attach the antenna to the pipe. Any kind of pipe will do , conduit , water pipe , plastic pipe , etc. , drill a hole through end of pipe put a screw through hole and screw into the rafter. Put boards in the attic for a walk way.
