Old 26-Jun-2011, 8:35 PM   #8
sundevilinok
Doesn't look like my last post saved. We'll try again. I took another look outside this morning, actually either end of the house would have tree obstructions. The middle part of the roof where the 2nd story rises up has a gabled end that would be a good un-obstructed location. Here's a picture:
The area circled in red is attic access I actually forgot about. We have 2 attics, a walk-in area above the garage the other being the behind that area circled in the picture. So, it would be an easier cable run from that location to the walk-in attic where our cable junction is at.
I understand it's all a one time fixed cost, I'm just trying to get an idea of what I need to budget for. It's looking like about 175 in hardware (antenna, gable mount, coax cable). Do you anticipate a need for anything to amplify the signal? It's going to be at least 30' from the antenna to the cable junction, then, could be around 50' to each of the TV's. Since I'll need to hire someone to do the work, I want to make sure and get everything done at once.
The last cost is installation. Any guess as to what I could expect there? Dumb question, who does one contact for this type of work (ie. tv repair, handyman, etc)?
Thank you again for your advice.
sundevilinok is offline   Reply With Quote
