Tv Antennas and Reception
You read the FCC rule correctly. Some how I thought that you said that your neighbor said you could use the upstairs balcony. And it is also true that antennas can be mounted on a patio or balcony. Any way here is a Tv antenna that looks like a small satellite dish. The Antenna Craft HDX1000. It has a built in amplifier , so no other amplifier will be needed. Yes it can be mounted up high because it looks like a small dish. I am doing my best to help you get broadcast Tv reception. http://www.antennacraft.net/Manuals/HDX1000_manual.pdf , http://www.antennacraft.net/pdfs/HDX1000.pdf
