Originally Posted by TickingMind
This happens every so often - Usually on a clear day. ...
I might add, during the rescan I began to pickup WXXI & WROC as well, there might be some correlation?
This sounds like tropospheric 'skip'. When conditions are right, you may receive distant stations. The atmosphere can act as a 'duct' or 'pipe' at times, but the phenomena is variable and its effect will vary depending on the signal frequency.
