Old 21-Jun-2011, 12:58 PM   #7
flixxx
Thank you so much for all of this information.
So i understand that classic cable will broadcast anywhere it can, including back out the antenna. On the other hand, if i were to subscribe to a satellite TV service, a Diplexer would do it correct?
About the pre-amp = How can one be overkill? I was under the impression that it cleans the signal before sending it to the TV's, it's possible to clean out the signal entirely or can the signal be too strong for the tv?
About the Antenna, John Candle, any particular reason why you recommend the Windegard HD 7694 over this one that I linked below? I'm only going on the specs that i can compare between the two but maybe i'm missing something?
Regards,
Flixxx
