Thread: Antenna Help
Old 20-Jun-2011, 6:47 AM   #7
Originally Posted by sphinxpup View Post
Thanks for your quick reply!
Do I for sure need the pre-amplifier? Is it something I can try with the antenna first and if it is not satisfactory I can add or should I just start with the preamp + antenna?
Just if you have time...what makes the antenna you recommend better then the on I was looking at? Because it is directional, or just a better antenna?
I have to use new coax because the other antenna used non-rg6 and the connector wasn’t working at all. (Like this http://www.summitsource.com/product_...oducts_id=8191 ) I wish I could salvage the other antenna but I can’t seem to get it to work.
Thanks in advance!
Feel free to try without the preamp. You can always go back up and add it if needed.
The Winegard will support reception of WTVI on real channel 11. The DB-4 is a very good antenna, but not a first choice for that task.
