Thread: Antenna Help
Old 20-Jun-2011, 3:56 AM   #6
sphinxpup
Thanks
Thanks for your quick reply!
Do I for sure need the pre-amplifier? Is it something I can try with the antenna first and if it is not satisfactory I can add or should I just start with the preamp + antenna?
Just if you have time...what makes the antenna you recommend better then the on I was looking at? Because it is directional, or just a better antenna?
I have to use new coax because the other antenna used non-rg6 and the connector wasn’t working at all. (Like this http://www.summitsource.com/product_...oducts_id=8191 ) I wish I could salvage the other antenna but I can’t seem to get it to work.
Thanks in advance!
sphinxpup is offline   Reply With Quote
