JC, you amaze us... He's in Canada and entered a postal code, therefore he doesn't have a Zip Code and TVFool's algorithm fills in the zip field with zeros.
sb1423,
Please run an exact address TVFool report and post that instead. We also need to know which Canadian mandatory market you're in so we can see what the post-transition situation is expected to be. Also, indicate if you're planning for post-transition only as your channel allocations and , hence your antenna requirements, are subject to change.
PS. The antenna you tried has a junk amplifier in it that overloads easily. Based on your postal code report, the use of any amplifier will likely be contra-indicated.
Reason: Edited to remove non-constructive comments
