Tv Antennas and Reception
Because of the 'Low Power' of the Tv transmitters and the 'Tall Pine Trees' and the 'Diverse directions' of the Tv transmitters I recommend a Big All Channel Antenna the Winegard HD7084P antenna mounted on a Channel Master Rotor model number 9521A. If your location is snuggled right in to the trees then you will need to get the antenna up as high as you can safely get. Or is your location in the areas that have been cleared of much of the trees??
