Old 17-Jun-2011, 12:45 AM   #33
gossamer
Originally Posted by John Candle View Post
WCBS Is transmitting on real channel UHF 33. Any way I have made my recommendation to receive the Tv channels at your location. You can choose your own antenna or go with what some else suggests.
John, thanks again. Once I realized the "Real" column was the one that should be used as the "real" reference, it was clear.
The Winegard HD7082P is designed to receive the low band tv channels 2 thru 6. Tv station WKOB-LD Real channel 2 has these digital sub channels , RTV http://www.myretrotv.com , TUFF TV http://www.tufftv.com , History Of Television Network http://www.hottvchannel.com
I checked out the websites for these domains, and it's unclear whether they broadcast in my area. Were you pointing these out because you know that they broadcast in the NYC area, and if so, can you point me to where I can find this out?
Thanks,
Dave
gossamer is offline   Reply With Quote
