Old 16-Jun-2011, 6:36 PM   #3
gossamer
More likely, it's either something at the station (perhaps they're running off an axillary system due to maintenance) or there is a new interference from something nearby that is affecting only that channel. It is highly improbable that something happened to your antenna that is affecting a single station.
I'd suggest waiting a day or two and seeing if your reception comes back, otherwise, call the station's engineering dept and make an inquiry.
Thanks so much. I thought that might have been the case, and in fact it was. An hour or so later, the channel returned, so it was indeed one or other reason.
Thanks again,
Dave
gossamer is offline   Reply With Quote
