If we enable the record for WTVF on channel 25, you will actually end up seeing two instances of WTVF. One on channel 5 and the other on channel 25. This is due to the quirky way in which these records have been entered into to FCC database.
We are working on a fix that will enable us to handle this strange exception case, but until that time, would you prefer to see a double entry for WTVF (showing both 5 and 25 transmitters) or do you prefer to see only the channel 5 transmitter (the one which is currently operating) and wait for the software fix to be done?
We have been busy processing data to enhance the accuracy of the models, so this particular fix, that so far only affects WTVF, may still take a few weeks to get implemented due to bigger changes happening behind the scenes.
