Old 15-Jun-2011, 2:38 AM   #6
overdrunk
Did you actually try the 91 XG without the amplifier? By without I mean totally disconnected, not simply unplugged.
I managed to receive the KTSF at 30% level through trying. I have a cable run of about 60ft, so I probably need the preamplifier. I tried once to mount the antenna on the roof, unfortunately, cannot receive strong signal, mostly due to the redwood tree just blocking the signal path. mounting it on the ground, the signal is much better.
overdrunk is offline   Reply With Quote
